I can’t get the Monte Carlo Ray Tracing Model to run on my Fluent simulation
    • moranlouie
      Here are the radiation settings:
      Doesn't run at all or diverges? What messages do you see in the TUI window?n
    • moranlouie
      I am getting the same warning you might have seen in my previous questions: nError at host: Monte Carlo radiation model set up is not correct.nIs it really just the use of a semi-transparent wall that is creating this error? If so, how do I simulate photon vectors going thru glass or transparent walls?nThanks!n
      Use a solid: it just says it doesn't like thin walls. n
Viewing 3 reply threads
