August 15, 2019 at 9:07 am
jirawin
SubscriberWhen i tried to open my project file it's show "Could not file '......'" and when i tried to save my project it's said "C/.... File not found. Check the file name and try again." how to fix this thanks.
August 15, 2019 at 9:15 am
Ansys EmployeeCan you check you've got a filename.wbpj and a folder filename? If you've moved these from somewhere else, put them back and try again. Within Workbench we save the project, and not a single file.
August 15, 2019 at 9:54 am
jirawin
SubscriberThanks. I can open file or save file now on drive C: but why I can't save on desktop ?
August 15, 2019 at 12:14 pm
SubscriberDoes your Windows username have a special character or a space in it? That may be the reason. Make a folder called C:ansysdata and save all your work under that folder, though it may be safer to make your username alphanumeric (English) only. The same goes for your computer name.
- unable to open files in ansys
- How to move duplicated ansys project position in workbench GUI
- Download MATLAB toolbox AnsysAAS
- An unknown error with memory occurred during solution.
- Desginpoints in Ansys 18.2 workbench got stuck at the stage of updating model in static structural
- Error: Unable to open some designs in this project – Corrupted project files
- Ansys solving system coupling problems on a remote cluster does not provide constant results.
- ANSYS Multi field 2-way FSI data coupling issue
- Material constant Damping calculation
- Different initial temperature conditions for two different object in transient-thermal
2524
2066
1279
1096
457
