I can’t set same colormap to compare two different simulations
    • Ines_
      Hi everyone!
      I am using ANSYS mechanical and I want to compare two different simulation results ( they are simulations of the same geometry under different loads). When I look at the results in postprocessing I need the same colormap in both to be able to compare them but I am being unable to do it. For example, I can't set the min and max values of the colormap.
      I think this is a really basic post-processing feature and I don't understand why it's so difficult to do it :,) any idea?
      Thank you so much Inés
    • dinhan0394
      you can double click or right click on the value and enter new value as you want
    • bhagwantP
      Hello Ines_,
      Will you please adjust stress contour in your analyis so that in both analyis it's similar and then you can compare.
      Thanks
    • bhagwantP
      You may find this one helpful:
      Thanks
Viewing 3 reply threads
