June 11, 2018 at 5:13 pm
June 11, 2018 at 6:16 pm
Aniket
Forum ModeratorHi Luiz,
The beam tool that you are trying to access is only applicable for line bodies. It seems that you are using a solid body to model the beam. In that case, it will not be applicable.
Aniket
June 11, 2018 at 6:23 pm
Luiz Henrique
SubscriberThank you very much.
May 31, 2019 at 4:15 pm
Devasish
SubscriberDoes this mean that if we are using solid body to model a beam we can;t have the BMD and SFD?? or is there any other way to obtain BMD AND SFD?? I am trying to model an I-section girder.
- The topic ‘I can’t use beam tools in the Mechanical (Ansys Workbench 19.0, Student Version).’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8824
4658
3155
1688
1482
