I could not find this Moveit app on ANSYS store. I am using ANSYS 2018.2. Can anybody share the appl
December 3, 2020 at 9:55 am
adnanam
SubscriberI could not find this Moveit app on ANSYS store. I am using ANSYS 2018.2. Can anybody share the application link please .n -
December 7, 2020 at 10:47 am
Navya C
Ansys EmployeeHi,nCan you provide below detailsnwhat Ansys tool are you working on? nWhat do you want to achieve using the Moveit app?n As far as I know there is no application called Moveit in Ansys store.nRegardsnNavyan -
December 12, 2020 at 5:36 pm
adnanam
SubscriberI'd like to use it in a simulated radar. Attach a video for more detailsnhttps://www.youtube.com/watch?v=X-rzW-gW4PQn -
December 16, 2020 at 4:44 pm
Navya C
Ansys EmployeenWe have discussed this with our team.nThis is not in the Ansys store at present. But you can get in touch with your local channel partner and they should be able to provide you with this ACT extension.nnRegardsnNavyan
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Concept of Interpolation Sweep in HFSS
- Error
8740
4658
3151
1678
1452
