November 22, 2020 at 4:44 pm
saadia
SubscriberI'm trying to validate previous data for my research but when I plugin the previous research values in Ansys fluent , I don't get any results. I'm using convergence factor 10e-4 and for the rest I'm attaching the screenshot. kindly help.
November 23, 2020 at 4:43 amKeyur Kanade
Ansys EmployeeCan you please explain in more details? What do you mean by plugin previous research values? nWhat is your operating pressure? nArrayRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnnNovember 23, 2020 at 5:38 amsaadia
Subscriberwhen i add the inlet and outlet conditions, I get an error Divergence detected - temporarily reducing Courant number to 5e-05 and trying again... Stabilizing Coupled to enhance linear solver robustness. n
November 23, 2020 at 12:18 pmRob
Forum ModeratorAnd the operating pressure? What is the material density? nViewing 3 reply threads- The topic ‘I don’t get any results when validating previous research data in Ansys fluent.’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
