May 6, 2018 at 12:32 pm
Tareq
Subscriberplease how can i export svg image from mesh drawing?
i tried print but it only give pdf and png
May 6, 2018 at 12:49 pm
SubscriberANSYS creates bitmap image files stored in png format like the one shown below.
If you want thicker lines, you can use the free software, ImageJ, and two menu picks:
- Process>Binary>Make Binary
- Process>BInary>Dilate
to get that, then you can Save.
There are several free websites that will convert PNG files to PVG, which is a Vector Graphics file, not a bitmap.
http://www.pngtosvg.com/ or https://convertio.co/png-svg/
These free websites also include a lot of buttons that lead to products to purchase or install, so don't click those.
The SVG versions created by the first website of the two PNG files above are in the attached zip file.
Why do you need SVG files?
- check element type
- Error in meshing
- Meshing Error
- How to resolve Mesh Failure
- How to get three elements across the wall thickness of a thin part
- Meaning of the symbol crossed out tick mark on a body in the tree outline indicate in Meshing
8708
4658
3151
1678
1448
