March 4, 2022 at 11:16 pm
viv_vid
SubscriberHello All,
So I am working on a project which is based on Mars. We are building a photobioreactor to cultivate Algae in Mars. My task is to maintain the water temperature of the tank in which algae is to around 20-25 degree celcius so that the algae survives.
Now I did my research on Mars and accordingly built my base 2d model and analysed the outside temperature and the Martian soil temperature. Since I am using Ansys fluent as a beginer I would appreciate any help. I am seeing many tutorial videos which are helping me.
Explanation of my model :
March 7, 2022 at 2:12 pmRK
Ansys EmployeeHello An Ansys employees, we will not be able to download any files.
After applying shared topology, Fluent will create a wall and wall shadow - the direction normal vectors will be the opposite on these 2 walls. I am not sure why you are using mesh interfaces.
March 7, 2022 at 2:47 pmviv_vid
SubscriberI was just following a tutorial video where there was a heat transfer between a fluid inside a pipe and the pipe walls. In that video he used mesh interfaces and coupled the interfaces, and he mentioned that you need to do this step, then only Fluent software will realize that there is a heat transfer between them. So if I am using shared topologies, I do not need to use mesh interface right?
March 7, 2022 at 3:39 pmViewing 3 reply threads- You must be logged in to reply to this topic.
2524
2066
1279
1096
457
