October 13, 2018 at 6:16 pm
Georgiro
SubscriberHello, I have a huge problem vith drawing 2D objects in drawing, because the thing that are drawed does not change their length, but the length is changed. Just absolutely optical problems
Problem to draw - no change of scale. But changing different dimensions. But the dimensions are not optically changed at all. How to do it? That is the question.
October 13, 2018 at 6:17 pm
Georgiro
SubscriberPlease, use my file, that has this crazy drawing with different scales and it should have only one. It you tell me what to do with it, it would be great or how to change it! Thanks
October 13, 2018 at 6:18 pm
Georgiro
SubscriberAlso now I am using version 19.2 Student. Thanks
October 14, 2018 at 10:38 am
Georgiro
SubscriberNobody able to reply? Is it true!
October 14, 2018 at 3:58 pm
SubscriberI downloaded your file that had a .rar.txt file extension. I renamed it to .rar and was able to extract the files from the archive. There was a DesignModeler file that I opened in DM but it was empty. The other file was a .wbpj file which is useless without the _files folder of the same name. When you create a Workbench Project Archive .wbpz file, those two items are automatically put inside an archive. Please do that in the future.
October 15, 2018 at 3:53 am
Keyur Kanade
Ansys EmployeeCan you please insert some images.
Keyur
October 15, 2018 at 2:33 pm
Ansys EmployeeDuplicate of https://forum.ansys.com/forums/topic/the-absolutely-serious-problem-is-again-to-skatch-a-new-model-because-i-change-the-dimensions/
Please use the linked thread above and avoid creating multiple threads on the same subject.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
