June 5, 2020 at 9:24 pm
fanaticreader95
SubscriberI am running ANSYS Fluent through workbench. So this problem occurred when I had an expression used in the y-momentum source term and completely deleted in and moved the expression to the x-momentum source term. Even after doing this it still says that the expression is being used for the y-momentum source term. I did make sure that even when I changed the y-momentum source to expression that everything was fully cleared before setting the y-momentum source to none, and then setting the number of sources to 0. The solution I found was that I had to entirely close fluent and then re-open it and that solved the problem.
June 8, 2020 at 12:56 pm
Ansys EmployeeThanks for reporting that. I'll pass it onto some colleagues who test that part of Fluent.
December 24, 2020 at 4:35 am
Jessica294
SubscriberThank you for sharing
- How to access the ANSYS Online Help
- search does not work.
- Discussion Creation Error
- unable to open the saved ansys file.
- Regarding not getting link of click “accepted answer”
- Images added to Posts are scaled UP and down
- Access to ANSYS Customer Portal?
- Access Denied Error When I Send Post
- ACP module does not start
- I have a student account and I can’t get my customer number. How I can fix this?
3694
2564
1765
1234
590
