February 1, 2022 at 5:29 pm
aramu
SubscriberI want to see the temperature profile, but it shows like that
February 1, 2022 at 9:26 pmFebruary 2, 2022 at 9:41 amRob
Ansys EmployeePlease put a plane through the domain in the meshing tool. I'm wondering if you've managed to mesh the casing boundary and pipe rather than the whole domain: remember in CFD we want the bits where the fluids are. Given CAD is usually of the solid parts it's not uncommon for people to not create the wet volume(s). You also want to look into Share Topology in geometry to avoid mesh interfaces: they have their uses but not sure it's necessary here.
If you've not done the tutorials, click on Help and run through a couple. You will also find we don't tend to post process in CFD Post any more, or use Workbench as much.
5290
3311
2471
