August 17, 2018 at 4:34 pm
August 18, 2018 at 2:43 pm
Karthik R
AdministratorHello,
Couples of quick questions:
- Are you reading the solver settings from a text file? At what step in your analysis do you get the error? Do you see this if you attempt to right-click and solve?
- Which tutorial are you trying to replicate? It might be useful to post the link?
Also, if you have not already looked, I'd strongly recommend you go to the ANSYS HowTo Videos page on Youtube. There are a lot of video tutorials available there. Here is a link. I hope this helps.
Thank you.
Best Regards,
Karthik
August 18, 2018 at 7:47 pm
Amrhossam96
SubscriberI’ve done the meshing step but when i double click the solver it brings that error, excuse me but i’m new to Ansys -
Amrhossam96
August 19, 2018 at 5:35 pm
Karthik R
AdministratorHello,
Have you looked into ICE to find if there is any settings which is attempting to read solver settings using a text file? Have you also looked into the properties? Right-click on ICE solver set and click on properties to open these options. You might perhaps find something odd there.
Another way to debug your issue would be to follow the tutorial from the ANSYS HowTo videos and see if you are able to reproduce the results. This might tell you if there is anything wrong with either your approach or installation.
I hope this helps.
Thank you.
Best Regards,
Karthik
January 23, 2019 at 1:14 pm
GuilhermeLopes
SubscriberHi,
I have the same problem, when I try to change option (EDIT SOLVER SETTINGS) show this message:
System.IO.FileNotFoundException: Não foi possível localizar o arquivo 'C:UsersguilhDesktopTCCdemo_tut_filesdp0ICEICEicSolverSettings.txt'.
Could you help me?
Thank you very much
Guilherme Lopes de Campos
2630
2104
1329
1110
461
