I have a problem on heat transfer
    • Gijoys4v
      Hallo,
      I have a problem on heat transfer. A solid with a source of heat generation is first at 50 Kelvin. It is then exposed to atmospheric temperature (300 K). The situation is, the solid’s heat generation is varying with change in temperature. How to give the heat generation which is varying with temperature in ansys workbench?
      Expecting a reply, thanks in advance
    • 1shan
      Please have a look at the Mass71 element. The element has a temperature dependent heat generation capability.
      Regards Ishan.
