August 27, 2018 at 11:06 pm
josemedina96
Subscriberhola muy buenas tardes, tengo un problema con ansys student, cuando lo instale funciono bien pero cuando lo fui a corar se queda trabado pensando que error podria tener
August 27, 2018 at 11:26 pm
pgl
Ansys EmployeeDear Josemedina96,
Thanks for your post. Our Student Community currently supports English, but fortunately Google Translate gave me:
"hello, good afternoon, I have a problem with ANSYS Student, when I installed it worked well but when I went to shut it down it got stuck with an error"
Could you provide a bit more detail to help us understand the error that you ran into? Could you grab a screenshot, explain what version of Student product, and what operating system you are using?
August 28, 2018 at 12:29 am
August 28, 2018 at 2:41 am
pgl
Ansys EmployeeCool. Glad you are running the latest release. Thumbs up!
So as I understand, the issue is that the Workbench solution status never completes, it gets stuck or slows down to a very very slow pace?
If so then this could be system resources issues, you could be low on RAM or physical disk space. Pop open the Windows Task Manager to see what the system situation is. Also what are the specs of the computer you are using, and how does that compare to the complexity (mesh density, simulation type etc) of the model you are trying to solve? Try and free up as much system resource as possible for ANSYS to "consume" and see if that helps.
August 28, 2018 at 3:44 am
josemedina96
Subscriberno creo que sea ese error porque mi pc tiene una RAM 16 GB y 1 TB de disco duro es un CORE i7 de 7 generacion, porque cuando analixo otros problemas mucho mas faciles pasa lo mismo
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2564
2080
1299
1106
459
