February 20, 2022 at 1:45 pm
goldenjet
SubscriberFebruary 21, 2022 at 5:24 pmFebruary 21, 2022 at 9:25 pmgoldenjet
SubscriberFebruary 21, 2022 at 9:30 pmFebruary 22, 2022 at 2:06 pmTomPhemmy
SubscriberHi, you have a large force over a small region on the hook. This is a problem. What's the dimension that you have scoped the remote force over? Also, is the behaviour of the remote force set to deformable?
February 22, 2022 at 2:53 pmFebruary 22, 2022 at 2:55 pmgoldenjet
Subscribercorrection, Yes the force is set to deformable. In addition do you think there is any problems with the loading conditions like for ex . the location of the Remote displacement and the frictionless support?
February 23, 2022 at 3:17 amgoldenjet
SubscriberI apologise for the question in parts, I would also like to know where should one be expecting a peak(maximum) Equivalent Von - Mises Stress? Either at the bend(mouth of the hook) or the lower fillet, cause I am a little confused about this part.
February 24, 2022 at 2:59 pmTomPhemmy
Subscriberto quickly go back to the convergence plot you show above, your solutions converged. so I don't understand why you say it doesn't converge. Regarding the boundary conditions, I cannot really say much if i don't have an idea of the physical problem you are trying to mathematically model. Why do you have remote displacements in the holes ? For the frictionless contact at the base, it does not prevent the bracket from sliding.
Why don't you use a simplified boundary condition that just gives you all the reaction forces and moment at the bracket of the hook? You are not modeling the bolts anyway.
You are applying a huge force of 49KN over a small region so you will have high values for stress. It also looks like you have a straight edge in your first figure above (a symmetry plane?) and your remote force is scoped to elements there too. This causes artificially high stress there.
is your mode 1/2 the full geometry? if this is so, where is your symmetry boundary condition?
Regarding your last question, can you show with pictures?
I think might be able to help you faster than I am.
Viewing 8 reply threads- You must be logged in to reply to this topic.
2656
2120
1347
1118
461
