May 10, 2021 at 9:04 am
arnt.bloch
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
With many objects (excep tvery simple objects) I am not at all able to apply variable rounds.
I want to create variable radiuses on a cran hook (file enclosed)), but I am not able to.
Can you help?
Enclosed file: Crane Hook
May 11, 2021 at 6:26 am
Charudatta Bandgar
SubscriberHello arnt. bloch
Let me look into this, I will get back to you.
Regards.
May 11, 2021 at 11:25 am
Charudatta Bandgar
It is probably because of the spline used to give the radius. And the variable radius applies along the line (or spline). I tried it with your geometry and I think it is doing it but not the way you intend. Try splitting the edge you are applying variable radius to and see if it works for you. Also if you could explain how you want the variablity, I can try it on my end as well.
3930
2649
1863
1272
610
