August 9, 2018 at 5:53 pm
derbaz
Subscriberi have i7 laptop i did the conflagration for parallel 7 and GPgpu 1 but when starts to run i got these massage
Cleanup script file is G:new softwarework filesangle 15 Ke Slvercleanup-fluent-WindTurbine-4836.bat
> Note: Rank = 0: Process affinity not being set (3).
Note: Rank = 1: Process affinity not being set (3).
Note: Rank = 2: Process affinity not being set (3).
Note: Rank = 3: Process affinity not being set (3).
Note: Rank = 4: Process affinity not being set (3).
Note: Rank = 5: Process affinity not being set (3).
Note: Rank = 6: Process affinity not being set (3).
So how can i solve it ?
August 13, 2018 at 10:02 am
Ansys EmployeeIf the solve still works just ignore it. I'd also recommend just using 3-4 cores as multi-threading and simulation aren't a good combination.
August 23, 2018 at 1:11 am
Karthik R
AdministratorHello,
Have you resolved this issue? If so, could you please post the resolution here. It might benefit someone who might have the exact same issue as yours.
Thank you.
Best Regards,
Karthik
2688
2138
1355
1136
462
