November 7, 2018 at 6:37 pm
JamesWright
Subscribertl;dr:
Rainbow colormaps are bad. I created two GitHub Repositories for better color map choices, courtesy of Kenneth Moreland. They are fluent_colormaps and cfdpost_colormaps for Fluent and CFD Post, respectively.
If any ANSYS reps see this, it'd be super nice if these could be officially implemented into new ANSYS versions!
If you have any questions or comments, please let me know!
Why not just use Rainbow like everyone else?
Generally, Rainbow is used as the color map for visualization, even though it has been proved to be quite poor for data visualization on a number of different levels. Information on this can be seen on Kenneth Moreland's website.
Here's an example of a SBES (hybird RANS-LES) simulation result at a single time step. The domain is axisymmetric with flow going right to left:
It can easily be seen that the brighter blue is drowning out the smaller scale turbulence. The use of a better color map can improve this dramatically:
There are dozens of other color map choices that are an improvement on the standard rainbow. I've compiled a imgur album of examples so that you can easily see the different options.
November 8, 2018 at 12:02 pm
Ansys EmployeeNice images. You do know that you can change the colour map in Fluent?
November 8, 2018 at 12:33 pm
JamesWright
SubscriberYes, but it's fairly tedious to do it manually. The GitHub repo has a function that can load and unload color maps without having to type it out one color space at a time.
November 8, 2018 at 4:34 pm
Ansys EmployeeNot really, you just change the scale setting. I'll flag the thread to DEV as it's a good idea.
November 8, 2018 at 9:02 pm
JamesWright
SubscriberTo be clear, I'm talking about the process of entering in new values to make a custom color map. Changing the color scale to one that's already in the system is quite simple. But a custom one would require that you enter in each 3 number color point on the scale one-by-one.
November 12, 2018 at 6:59 am
Keyur Kanade
Ansys EmployeeI think this is available in ANSYS EnSight. But unfortunately EnSight is not available in student version.
November 12, 2018 at 6:02 pm
JamesWright
Think what is available in EnSight? I'm running an research academic license, so I might have access to EnSight.
November 12, 2018 at 6:16 pm
DrAmine
Ansys EmployeeNice post!
November 12, 2018 at 7:44 pm
Karthik R
AdministratorHello,
This is nice suggestion.
Regarding Keyur's comment on ANSYS EnSight and about available color maps, please have a look at the following post. It explains how to get to changing the color palette on EnSight. Please note that ANSYS EnSight is not available for the student version.
https://forum.ansys.com/forums/topic/ensight-hot-iron-palette-from-an-image/
Thanks again for your inputs.
Best Regards,
Karthik
November 13, 2018 at 1:35 pm
Ansys EmployeeYou can also use a journal to create the scales: not necessarily trivial but I don't know how much effort you put into the other images.
As an aside, the feature is on the "to consider" list for Fluent next year: thanks for the suggestion.
November 13, 2018 at 2:24 pm
JamesWright
SubscriberOnce I found the script for adding the colormaps, I simply made a quick Python script to turn the csv's on Kenneth Moreland's website into the correct file format, so it didn't take very long. Also makes it much easier to add new colormaps in the future if they come about.
That's great to hear! I'd love to keep up with the ideas progress if that's possible!
November 14, 2018 at 9:49 am
Ansys EmployeeAs a user the only way will be to read the release notes: they're about the first entry in the list in the documentation. Unless we're testing internally we may only find out about a feature a few weeks before release during out update training.
Alternatively, keep watching the careers page, apply & get through the process and maybe get access to the pre-release software!
November 14, 2018 at 1:38 pm
JamesWright
I'll keep that in mind! It'll be a few years before I finish up with school (doctorate), but I'll definitely be looking here when the times comes.
2656
2120
1345
1118
461
