I NEED HELP PLEASE !!!
    • Aymanbali
      i want to do a structural mechanics study on a mesh i have , is there any way to import the mesh in Mechanical ? i already have a mesh generated i just want to import it and do the study on it.
      thanks in advance
    • peteroznewman
      In Workbench, look in the Toolbox and below the full analysis systems are Components. One of them is External Model. Drag one of them out onto the Project Schematic. Edit that and point to the mesh file and Update.  Drag out a Static Structural.  Drag the External Model Setup cell onto the Model line of the Static Structural.
      • What program generated the mesh?
      • What export format was used to write the mesh out of that program?
      • Where was the geometry created for that mesh?
    • Aymanbali
      thank you for the answer , i generated the mesh in a program called rhinoceros , i could export in many formats, what format would be the best? the geomatry for that mesh i did also in rhinoceros
    • peteroznewman
      The best format is ANSYS, the next best is NASTRAN, then ABAQUS. What formats are available?
    • Aymanbali
      i did in NASTRAN , and it seems that it works.
      Thank you very much sir
    • peteroznewman
      You're welcome.
Viewing 5 reply threads
