September 29, 2023 at 7:22 am
Mohammad Chowdhury
SubscriberHi,
I am trying to do a fluid flow simulation for a double pipe heat exchanger but it is not converging. I have tried refining the mesh, changing velocity for inlet and outlet but no luck. can anyone suggest me how to get the convergrnce. I have attached some pictures here. The residual factors are set as default.
September 29, 2023 at 11:11 am
Forum ModeratorAssuming you have velocity in and pressure out I'd be looking at the mesh and add some point monitors to understand the flow field.
September 29, 2023 at 1:38 pm
Mohammad Chowdhury
SubscriberYes, it is velocity in and pressure out. What do you mean by point monitors?
September 29, 2023 at 2:10 pm
Forum ModeratorUnder Surface creation you can add points to the domain, and then Report Definitions to those.
In an unconverged solution the problem can be mesh or setup related or that there is something going on in the flow field. The monitors and images taken every few iterations can help identify the issue.
- Floating point exception
- How to indetify baffles in Fluent meshing
- How to delete elements on Ansys Workbench
- Meshing cylindrical bodies with holes
- Quality failure limits are exceeded on some solid bodies… in ansys meshing
- Problems in the meshing of my geometry
- Ansys Mechanical – Python Scripting – Access and input parameter
- Fluent Meshing Batch Mode – Problems workflow commands
- Local mesh refinement with targeted edge lengths at specified areas
- Mesh Element Quality Display Style Not Showing
8808
4658
3153
1680
1470
