March 26, 2021 at 6:52 pm
san
SubscriberI have modelled a spring attached to shock absorber system nBut I don't know under which domain should I test them nTransient structural or static or other n -
March 26, 2021 at 8:29 pm
SubscribernThat depends on the test definition. What results do you need from a model? Do you have experimental test data to correlate the model with?n -
March 26, 2021 at 8:39 pm
san
SubscriberHi sire nI need the model to be stable when loaded with At least 10KN of loadnGenerally normal absorbers tend to take on with load of 2 to 3kN and be stable nI just need to know the maximum amount of shock it can absorb n -
March 26, 2021 at 8:44 pm
san
SubscriberThe model is novel system and different from existing one, but it incorporates a shock absorber in itnnI need only to check the shock absorbing capabilities n -
March 27, 2021 at 12:53 am
SubscribernUse Transient Structural. Please insert an image of this novel system so we can see what you are working on.n -
March 30, 2021 at 12:12 am
san
SubscriberThank you sire for your advice nThe system has to be patented nSo is it safe to share image in this forum n -
March 30, 2021 at 12:28 am
SubscriberNo, you can't disclose the invention before the patent has been filed.n -
March 30, 2021 at 12:30 am
san
SubscriberOK sire nI will try with transient first nAnd if I don't get proper results, I will get back to you nThank you very much n
Viewing 7 reply threads
Trending discussions
Top Contributors
2616
2098
1323
1108
461
Top Rated Tags
