February 4, 2021 at 1:38 am
Chae_junior
SubscriberIn the nodes arranged as shown in the figure, if stress is applied to the node at the center point, the nodes will change as shown on the left.
February 4, 2021 at 12:54 pmAniket
Ansys Employeecan you please explain more about the boundary conditions and software tool that you are using? n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning ForumnFebruary 5, 2021 at 12:39 amChae_junior
SubscribernI am using a 3d tetrahedron mesh. I am using frictionless contact and I am using ansys 2020r2. The boundary condition used is displacement. It started from 0 and increased by a certain distance. Also, both ends were fixed.February 5, 2021 at 12:09 pmAniket
Ansys EmployeeI don't think you can pull just one node, while being connected to surrounding nodes and keep the surrounding nodes at the original position, (unless they are fixed artificially using displacements).n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning ForumnViewing 3 reply threads- You must be logged in to reply to this topic.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
5454
3419
2473
1310
1022
