July 23, 2019 at 2:28 pm
DG89
SubscriberHi everybody,
I did not undestand why the mderator locked the topic: "I want to see the failure!", since I have not jet resolved my doubts.
So, I refear to it for previous posts
https://forum.ansys.com/forums/topic/i-want-to-see-the-failure/
I answer to peteroznewman
as you can see in the attached figure, the number of steps set by me in the file is not 0 but 1, so, I do not understand why the program read 0. I have also tried to increase that value but the error still exists.
July 31, 2019 at 3:11 pm
DG89
SubscriberDear peterznewman,
I tried to re-do the exercise proposed in the file shared by you, but it does not run. I set all parameters in the same ways but the error message occured again.
- firstly, I had to add the "bi-linear histropic hardening" behaviour to the default steel material in order to see plastic strain.
- more over, when I passed from the plastic analysis to the failure analysis (ekill script) the program does not solve the problem, and thefollowing error appare in the "solution information":
PARAMETER FAIL_STRAIN = 0.000000000
PARAMETER STEPS = 0.000000000
*GET TIME_END FROM common ITEM=STEPCM REAL N= 2
VALUE= 500.000000
*** ERROR *** CP = 0.391 TIME= 16:44:07
Attempt to divide by zero in parameter expression.
The above error occurred processing field= TIME_END/STEPS
Line= *SET,timeinc,(TIME_END/steps).
PARAMETER TIMEINC = 0.000000000
So, i tried to eliminate the following lines (7-9 lines) from the script in the command line:
timeinc=TIME_END/steps
time,timeinc
solve
Now the program end the solution process but I do not obtain the expected result.
Please, help me to understand the error
July 31, 2019 at 5:16 pm
SubscriberI don't write scripts, I only use them. Other members are welcome to take a look.
Good luck.
July 31, 2019 at 6:18 pm
DG89
SubscriberOk peterznewman, thank you anyway.
Somebody else?
2066
1283
1096
459
