February 17, 2021 at 10:55 am
Harish04
SubscriberFebruary 17, 2021 at 10:56 amHarish04
SubscriberThe channel has two different inlets and one common outlet. My results are not converging. Kindly please help me if anyone has any idea.nFebruary 17, 2021 at 11:21 amRob
Ansys EmployeeI'd start by checking the mesh, solver settings, models used, boundary conditions and time step. nFebruary 17, 2021 at 11:31 amHarish04
SubscriberThe same thing I did but, in the end, it showed Abnormal exit.nIf you have any tips kindly please help me.nnFebruary 17, 2021 at 4:10 pmRob
Ansys EmployeePlease post some images of the solution before it fails, boundary conditions etc. I've done these models before, so they do work. Note, there are no tutorials on this specific application, you need to read around and look for examples on VOF and surface tension. nFebruary 18, 2021 at 4:47 amHarish04
SubscriberCan you please contact me on #####@gmail.com, so that I can discuss with you if it's okay with you?nFebruary 18, 2021 at 11:25 amRob
Ansys EmployeePlease post the images etc as I asked. All communication is via the Forum. nViewing 6 reply threads- You must be logged in to reply to this topic.
5268
3299
2469
