November 8, 2020 at 3:38 pm
Ansysstudent5361
SubscriberHi,
I'm looking at wind loading on rooftop located solar panel. I wanted to ask if my geometry was correct for the modelling. This looks like what I want but functionally is there anything I should do? Should I separate the solar panel and building as two solids? What are some best practices for geometry creation so I can mesh this easily and get accurate results? I have not created my fluid domain yet but its just an enclosure with domain dimensions taken from literature. I'm asking this because my previous model was a real pain to mesh and did not mesh properly so I started from scratch again. Can someone guide me on meshing this? This is a single solid.
November 9, 2020 at 9:45 amKeyur Kanade
Ansys EmployeeDuplicate of
Regards Keyur
Viewing 1 reply thread- The topic ‘I wanted to verify my geometry.’ is closed to new replies.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
8808
4658
3151
1680
1470
