Tagged: micro-mechanics, nanoparticle, Thin-Modelling, thin-solid, thin-surface
March 22, 2022 at 9:32 am
Hassan.liaquat
SubscriberI trying to make a simplified model of the human cell.
The cellular structure consists of the outer Plasma membrane, filled with viscoelastic fluid and nuclear and nucleoplasm. Outer Dia of the cell is 14 micrometers, however, Plamsamembrane is 10 nanometers thick which I am unable to model in Ansys. Do you know any way to model that? I will be performing modal analysis later on.
March 22, 2022 at 12:26 pmpeteroznewman
SubscriberRead this discussion: https://forum.ansys.com/discussion/33803/creating-nano-scale-layer
March 22, 2022 at 12:34 pmHassan.liaquat
SubscriberDear Peteroznewman
Thank you for your comments; I did go through your post a few days earlier; great to hear from you. Can you please tell me whether it will work for spherical shells? Because the option you said is about the surface coating.
March 22, 2022 at 12:35 pmHassan.liaquat
SubscriberMarch 22, 2022 at 12:40 pmpeteroznewman
SubscriberYes, a surface coating works on flat or curved faces of solid or shell elements.
March 22, 2022 at 12:42 pmHassan.liaquat
SubscriberThankyou very much, i will have a try
Viewing 5 reply threads- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2706
2146
1357
1144
462
