Preprocessing
Preprocessing
I wants to perform modal analysis of a body present in a viscoelastic medium
    • Hassan_AUT1991
      The spherical shell body is present in a viscoelastic medium; what type of contacts and elements I shall use between the medium and spherical body. (I am trying to simulate a biological environment)
      The body also contains fluid within; what type of contact I shall define between the body and fluid within?
      Kind regards
    • Vigneswaran Sridharan
      Hi Modal analysis is alinear analysisso we can not include nonlinearities (large deflections, contacts (frictional), and material nonlinearities). We can ofcourse include large deflections (geom. nonlin.) in a static analysis (and of course plasticity and frictional contacts), but not in modal.
      The viscoelastic model is used when the large-deflection effects are active (NLGEOM,ON).
      I suggest you look at this forum discussion modal analysis for structures under water considering p-delta effect (large deformation/deflection) ÔÇö Ansys Learning Forum
      Vigneswaran
      Ansys Help
      Rules & Guidelines ÔÇö Ansys Learning Forum
