I wish this error from the console could be more specific:
    • moranlouie
      ------------------------------------------------------------------------------------------------------------------------------------------------------------nOnly mapped interfaces are supported with Monte Carlo radiation modelnnWarning: Monte Carlo radiation model does not support wall thickness for semi-transparent wall:nt A wall thickness of zero will be used for radiation calculation at wall 17nnError at host: Monte Carlo radiation model set up is not correct.n------------------------------------------------------------------------------------------------------------------------------------------------------------n
    • moranlouie
      .n
      That looks pretty clear. Don't use interfaces other than mapped: I'd try and avoid mesh interfaces altogether. Wall thickness for thin walls isn't supported, so either use a solid zone or accept that the radiation will go straight through it with zero absorption or reflection. n
