ic engine analysis
    • veera
      dear sir
      i am simulating the ic engine (diesel -air mixture) with species transport and finite rate
      what is the Exponent term while setuping the reaction and protectant ..if i keep everything one i am getting result lesser peak pressure and if i very the exponent term from 1 to 0.5 or different different values that pressure also changes with temperature what is the appropriate value we need to set for corresponding reactant coefficients?
      #but my coefficients are correct
      If you click on the Help button the panel documentation will appear, that usually has links to all of the options available. n
    • veera
      i am using student version, so help wont work, any other waysn
