IC engine simulation
    • rishuhcdefs
      hi
      i need to run simulation for a Toroidal IC engine which dosen't contains crank, conn. rod and other stuff instead gears are used to drive the system. can you pls help me on as how to proceed with the simulation, secondly I should opt for FLUENT or FORTE
      thank you!
      If it's a Wankel Engine you'll need moving mesh, and it'll not be simple. You'll also want Fluent for the mesh motion.
