November 29, 2017 at 7:24 pm
November 29, 2017 at 11:02 pm
raul.raghav
SubscriberAs the pre-mesh to unstruct mesh is complete, ICEM-CFD should load a ".uns" mesh file. For some reason it is not able to locate the ".uns" mesh file. Does your ICEM-CFD have admin rights to write files in your working folder? If I were in your shoes, I'd try
1. Saving the ICEM project in a different folder and trying this process again, or
2. Run ICEM as administrator and see if that would fix the issue.
Good luck!
November 29, 2017 at 11:14 pm
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2616
2098
1323
1108
461
