August 12, 2019 at 3:18 pm
kmkb21
SubscriberHi there
I have been attempting to mesh a 2D airfoil in bounded flow, and have not been able to produce a mesh without errors. After computing the mesh, it says that there are holes in the mesh and asks if i'd like to see them, and then shows tets on the boundaries and bodies. The errors are as follows:
Your geometry has a hole, do you want to repair it?
and
too many open faces
.... and 180058 more error messages ...
faces are missoriented
I have set global parameters and part parameters.
Am I missing a step?
Thanks!
August 13, 2019 at 9:21 am
Ansys EmployeeI'd suggest switching to Workbench (ANSYS) Meshing as it's much easier to use. ICEM CFD is mainly used for complex 3d hex meshes and isn't the most novice friendly of the ANSYS products.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1279
1096
457
