October 22, 2018 at 7:35 am
CatiaV5
SubscriberHi guys,
I have the following geometry (see picture below). I have blocked it in ICEM (see also below). When I get the pre-mesh the mesh lines are running towards a point (see attached picture) instead of running parallel to the edges. I would like to sort this out but I have no idea how. Can anyone help me out please?
October 22, 2018 at 8:15 am
Keyur Kanade
Ansys EmployeeHello,
Please use edge association correctly. Also make sure that you have not merged any vertices.
Following video may help you .
Keyur
Keyur Kanade
Ansys EmployeeHere is link.
Keyur
October 23, 2018 at 4:09 am
Keyur Kanade
Did it help you? Are you able to get hex mesh?
Also, please like the answers which have helped you move forward and in the end, once your issue is resolved, please mark the most appropriate solution (most useful advice) as 'Is Solution'. This will help others who are using this thread to find answers to similar questions.
Keyur
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2564
2080
1293
1106
459
