November 24, 2020 at 12:19 pm
ai0013
SubscriberHello
Could anyone give me an insight on how to fix the "volume orientation" problem? This seems to be ocurrying in the elements next to the wall of the sphere. The bad elements are colored in red.
November 25, 2020 at 5:49 amKeyur Kanade
Ansys EmployeePlease assign edges and faces of the blocks correctly. nPlease see videos on blocking.n ANSYS ICEM CFD: Mesh Improvement using Ogrid Split - YouTubennPlease see help manual for more details about these commands. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnnNovember 25, 2020 at 11:34 amai0013
SubscriberKkanade,Thank you very much for your reply. Is it necessary to associate the outer edges to the sphere surface? These are catched up automatically when I click on projected edge/mesh shape. If so, how can I associate the edges to the sphere if I dont have any curve defining the sphere? The only geometry inherited is the surface item.. Should I manually create curves surrounding the sphere and then associate?.I manually blocked all fluid region dilimited by an injection nozzle contained within a spheric wall, So my fluid region is nothing but a sphere without the volume occupied by the nozzle, this is why I have lots of blocks for my sphere..n
November 25, 2020 at 1:15 pmKeyur Kanade
Ansys EmployeeYou can assign faces. nAlso move the nodes of blocks appropriately. nPlease see help manual for more details about these commands. nnRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnnViewing 3 reply threads- You must be logged in to reply to this topic.
Trending discussions- check element type
- Error in meshing
- Meshing Error
- How to resolve Mesh Failure
- How to get three elements across the wall thickness of a thin part
- Meaning of the symbol crossed out tick mark on a body in the tree outline indicate in Meshing
8786
4658
3151
1678
1468
