March 3, 2022 at 7:22 am
mikiluv1
SubscriberDear all,
I am simulating heat (temperature) characteristics on SIW using the Icepack tool. WHEN THE THICKNESS OF THE SUBSTRATE IS LESS THAN 0.5MM, IT DISPLAYS ERROR MESSAGE with the details seen in the image attached. I would be the happest man if anyone could help me out ot explain otherwise.
March 7, 2022 at 5:59 pmPraneeth
May I know the resolution of the mesh in Icepak?
Please try using more finer mesh and see if it helps.
You can also use some mesh operations at minute details in your model. Please go through "Assigning Mesh Operations" section in the Icepak help document.
All the very best Praneeth.
- Maxwell, HFSS or Q3D?
- Error
2666
2120
1349
1132
461
