March 21, 2023 at 12:12 am
Matthew Rich
SubscriberHi
I am using electronic desktop 2023 to model thermal and magnetic field strength of an electromagnet. I am getting very hot temperatures very quickly with the air being hotter than the coil which is producing the heat. I have a picture below to give an idea of what I am talking about. I am running a 3D transient analysis and I have an ambient temperature of 37C. I am placing 24V on a coil terminal or 0.6 amps into a coil with a total resistance of 38.9 ohms. I do anticipate the temperature of the magnet to rise but not to be outpaced by the air. I have free opening BC on all faces of the air region. What I want to have reflected is that external processes will regulate the air temperature so it is always 37C. How can I achieve that? and why is my air so hot?
Thanks in advance
April 3, 2023 at 3:13 am
Navya C
Ansys EmployeeHi Matthew,
Please review the below course to check if you have setup everything correctly.
ETM Using Ansys Maxwell and Icepak - ANSYS Innovation Courses
Navya
- Maxwell, HFSS or Q3D?
- Error
5242
3299
2469
