January 6, 2023 at 12:33 am
Reagan Terpstra
SubscriberHello!
I am trying to export some transient thermal data from ICEPAK but I am not having much success. The field summary is able to pull about 20 data pieces but I have a little over 100 data pieces I would like to grab. Is there setting I need to change or another avenue I should pursue to accomplish?
Thanks!
January 9, 2023 at 1:16 pm
Pdev
Ansys EmployeeHello Reagan,
You would need to specify the data point save frequency otherwise, the default settings will be used and it's usually coarse.
PDev
- Maxwell, HFSS or Q3D?
- Error
2706
2142
1355
1144
462
