ICEPAK – Mesh recycling of mesh regions
    • JanHa
      Hello,nI am wondering if there is a way to reuse mesh regions from one ICEPAK solution to another? nIn my particular case, I am trying to analyze the thermal management of a PCB. I would like to reduce the efforts of meshing the PCB (with all the traces, vias planes etc.) Therefore, I assigned a meshing region around it and would like to reuse the mesh generated in that region in other designs.nI tried to assign a Mesh operation, which allows to include a .msh file. However, I am unable to find/generate the .msh file from previous simulations.nAny idea how to do this? nThanks!n
    • Satyajeet Padhi
      By default, mesh is created for all objects in the model each time it is generated. You can reuse mesh for specific objects or shapes if a mesh has been generated for them previously in a different project. The supported mesh file types are the Icepak grid_output file or a Fluent .msh file.nPlease refer to the section in the user guide (linked below)nhttps://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/ice_ug/ice_ug_sec_reusing_mesh.htmln
