October 31, 2018 at 10:02 pm
upot2
SubscriberHello,
I seem to be having issues running Icepak on my computer. I have an ANSYS CFD Research License installed, however when I open up Icepak, I am not able to click on any of the options. Neither does it show the default window of 'Open Existing', 'Unpack'. Right now, it's basically a blank Icepak window with the toolbar grayed out. When I open up Icepak through Workbench, it works fine allowing me to run the simulations as expected. So basically Icepak does not work when I open it up through the Start Menu. ANSYS Spaceclaim on the other hand is working fine. I have attached a screenshot of the blank Icepak image.
Could someone tell me what the issue maybe?
Thanks
October 31, 2018 at 10:57 pm
Karthik R
AdministratorHello,
On first glance, it seems like a systems issue. I'm moving your question to the 'Installation and Licensing' thread for better visibility. I hope this helps.
Best Regards,
Karthik
October 31, 2018 at 11:26 pm
tsiriaks
Ansys EmployeeHi upot2,
Can you try renaming the file .icepak_defaults under C:Users
to something else, like old.oldicepak_defaults
If that doesn't help, Open CMD Prompt, then type 'dxdiag' (without quote ' ') . Once the dxdiag gui is launched, go to 'Display' tab and take screenshot , then post it here.
It might also be worth trying to set this environment variable ICEPAK_JOB_DIRECTORY with its value being the path to the working directory. You can specify the path something like C:Temp
Thank you,
Win
November 1, 2018 at 3:25 pm
upot2
SubscriberHello,
Could someone help me with this issue? It has not been resolved.
Thanks
November 1, 2018 at 3:59 pm
tsiriaks
Can you post the screenshot of the 'Display 2' tab as well ?
Do you have a dedicated graphics card like Nvidia, AMD on the machine ?
The ICEPAK_JOB_DIRECTORY is the Windows environment variable. You can set an environment variable by following these steps
https://www.java.com/en/download/help/path.xml
The value can be any path that you want your Icepak job to be written on. But for this test, you should specify something simple like C:Temp
Thanks,
Win
November 1, 2018 at 4:21 pm
upot2
SubscriberHello tsiriaks,
I tried setting the environment variable as you suggested-it did not work. With regards to the display, this should not be the issue since I have used ANSYS on the same computer with a previous license without any issue. Right now, Icepak opens up but the toolbar is greyed out and it does not allow me to select any of the options. Closing the window too isn't allowed and I'm forced to shut it down by opening up task manager and ending the task. It works fine when I open Icepak through Workbench. Anything else I can try?
Thanks
November 1, 2018 at 6:16 pm
David Yakinian
Ansys EmployeeHello,
Are you running dual monitors? Is your primary monitor the right monitor? If you are, try this out, I've seen something like this before. Change your primary monitor to the left one.
Right click the desktop, screen resolution, click on the left monitor, make primary. Might differ depending on your OS, I am on Windows 7.
If this doesn't apply, disregard. -
November 1, 2018 at 6:36 pm
upot2
SubscriberHi Dyakinian,
Thanks a lot! Changing the main display worked.
November 1, 2018 at 7:06 pm
David Yakinian
Ansys EmployeeThis is a very specific bug, it looks like there is no issue with 19.1.
January 28, 2023 at 2:50 am
- Workbench error
- Workbench not opening
- License Error
2726
2148
1359
1150
462
