Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
Icepak PCB with vias
    • Yin Fang
      Hi there,
      I am using the PCB function in automation page try to configure my PCB:
      I would like to generate PCB with 2 groups of round vias like this:
      However the module only alow me to drill 1 via for 1 instruction:
      The second box "Via Details" seems not working. I can not have multiple vias by setting this, and the plate material is also not displayed for the genrated PCB. The plate is not visible for the created PCB.
      I am so confused with it and I can't find anything related to this online. Thank you for anyone's reponse.
      Yin Fang
    • Iceman
      Hi Yin,
      You can use the Add button to add additional vias. The Configure Vias is only available for Compact PCB type. You will only get lumped PCB and Vias with proper material properties. The Via Details will change the effective thermal conductivity. If you want to get the layers of the PCB, you will need to use the Detailed PCB type. Thanks.
      • Yin Fang
        Hi there,
        Thank you for your reply! Is that means If I have 40 vias I have to get each via individually by the add buttom? I cannot add one group of vias together?
        Yin Fang
    • Iceman
      Each Via represents a group of vias together as a lumped solid. There won't be holes created for each individual via. Then material properties will be automattically calculated based on the Via Details setting.
      • Yin Fang
        Thank you for your explanation. I think I got it.
        Yin Fang
