Icepak R18 tutorial heat sink problem
    • diptanshu18
      Hello all, I was trying to solve the 1st problem from the Icepak R18 tutoral (heat sink problem) in Icepak R21. My temperature values do not correspond to the temperature values from the tutorial's solution, could someone please help me with this?
    • Praneeth
      Please use upload image option in the post, as Ansys employees we cannot access the attachments across the forum.
      Thank you for your co operation.
    • Satyajeet Padhi
      I ran the tutorial on my end in 2021 R1. The results obtained in Icepak 2021 R1 match with the results shown in the tutorial. Please re-run the tutorial on your end following the instructions carefully.
