October 31, 2023 at 3:52 pm
Caleb Wood
SubscriberHello,
I am trying to extract both the drag force and inertia force from my LS-DYNA model which uses the ICFD method. The model is pictured below and consists of waves impacting a rigid piled structure which is eventually to be made elastic (steel). I am able to use ICFD_DATABASE_DRAG which outputs "Fp" and "Fv", which to the best of my knowledge are the pressure drag force and viscous drag force respectively.
I believe that Fp may be the drag force as it closely matches my hand calculations using the Morrison equation, however I am unsure of how to obtain the inertia force or the total drag force for the matter. Any insight on this topic would be greatly appreciated. Thank you.
November 3, 2023 at 11:28 am
Ashish Khemka
Forum ModeratorHi,
Please see if the following links help:
How to extract reactions from rigid body in LS-DYNA (ansys.com)
Force Analysis — Welcome to the LS-DYNA support site
Ashish Khemka
- Explicit dynamics ERRORS
- turning simulation
- explicit dynamics
- Monte Carlo Simulation
- Error inside ANSYS LS Dyna: “An error occurred inside the SOLVER module: general error.”
8778
4658
3151
1678
1460
