ideal gas law and imcompressible ideal gas
    • Weiqiang Liu
      Hi all,
      During my recent simulation work, I found an interesting thing. That is if I use imcompressible ideal gas to calculate density of mixture, results would be a mess. In other words, results are very unreasonable. However, if I use ideal gas law as density method, results would be very reasonable.
      Ps: I used laminar flow in my model.
      I am wondering why would this happen?
      Best regards
      Weiqiang
    • RK
      Hi Weiqiang,
      Note the difference between using the incompressible and the ideal gas model for density. For the incompressible ideal gas, the density is a function of only the operating pressure where as for the ideal gas law, density is a function of the sum of operating pressure and gauge (local) pressure.
    • DrAmine
      That is obvious especially in case of closed cavities or flow underlying strong pressure variations.n
    • Weiqiang Liu
      Hi all,nReplying to individual comment is not allowed in new version of this forum? Anyway, thank your guys for giving me suggestions!nBest regardsnweiqiangn
Viewing 3 reply threads
