February 17, 2022 at 6:45 am
Jimmy081
SubscriberHi,
I want to do a simulation for a film cooling plate with structural mesh.
I want to reduce mesh number in the streamwise (x) and spanwise (z) directions at freestream zone, so I want to use overset mesh.
If I want to have LES as turbulence models, can I use overset mesh in FLUENT?
Thanks.
February 17, 2022 at 2:31 pmMurari Iyengar
Ansys EmployeeHi Jimmy081 Unfortunately, LES model is not compatible with overset mesh. For more information on Overset Mesh Compatibility and Limitations, please refer to the link below.
6.6.7. Overset Meshing Limitations and Compatibilities (ansys.com)
Trending discussions- how to improve the inflation quality at sharp corners?
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
3682
2552
1759
1232
584
