September 4, 2019 at 10:44 am
Talal
SubscriberHello,
I am trying to import an .igs file that I made with catia v5. The problem is that the geometry doesn't come as a solid. Being a not-that-planar geometry and being quite complex, i don't think that shell elements would be appropriate here. Here is a picture of it:
How could I import this .igs file as a solid or do you have a way to make it work anyways?
Btw, when opened in design modeler, the geometry is considered as a solid in the tree:
But when opened in the preprocess window i get this:
with over 7k free parts with each asking for a thickness. (kinda lost)
September 4, 2019 at 1:28 pm
Forum ModeratorWhich licence are you using? I'd tend to use STEP format for file transfer, IGES is notorious for giving odd results and losing higher order bodies. Have you got solids in Catia, and which solver do you plan on using?
September 4, 2019 at 1:56 pm
- The topic ‘.igs file read as faces’ is closed to new replies.
- Unable to attach geometry 2024 R2
- Data Center Simulation
- [SpaceClaim] STEP file size using Converter.exe
- Spaceclaim 2024 error FNE activation failed
- How to do the snap fit insertion FEA?
- Ansys Discovery Crashing vGPU (Reproducible)
- PMI Product manufacturing information in SpaceClaim/Discovery modeling
2723
959
813
599
591
© 2025 Copyright ANSYS, Inc. All rights reserved.
