Preprocessing
Preprocessing
Topics relate to geometry, meshing, and CAD
Illegal connectivity
    • Yahhhh Sultiii
      Hii,
      I have problem while l reaching the solution of hydrodynamic diffraction. Yeahh, I met error result, illegal connectivity it said, " Element 3681 is joined to element 7821 and element 8091 . What the solution to solve this and what the problem exactly found?
    • sxdu
      Aqwa only requires the external hull surfaces to generate meshes for the hydrodynamic diffraction analysis. Having the connectivity problem is mostly caused by the compments inside the hull were modelled.
      You can use Ags to visualize the Aqwa panels. Some operations described in Aqwa Graphical Supervisor Users's Manual, Section 11.3 Selecting QPPL& TPPL Elements may help.
