March 23, 2022 at 6:44 am
ighosh
SubscriberWhile doing a Hydrodynamic Diffraction Analysis in Workbench; I note that the Mesh Based and Mass Based displacement has difference of 198.8%. The absolute values are quite close but the mesh based displacement is negative which is incorrect. I have a feeling that there is a problem with coordinate axis. Did anyone face similar issues? How did you resolve it. Please help me.
March 23, 2022 at 4:05 pmMike Pettit
A negative mesh-based displacement means that the surface normals of your vessel are pointing inwards, instead of outwards. A quick way to check this is to turn on part highlighting (View > Highlight Selected Parts and Bodies) then select the Part in the Outline tree. The outside surfaces should be highlighted in bright green:
If the surface normals are wrong, then the insides will be bright green and the outsides will just show green edges:
If this is the case, you'll need to go back into SpaceClaim or DesignModeler and flip the surface normals.
I hope this helps!
Mike
March 24, 2022 at 4:27 amighosh
SubscriberThanks Mike.
2726
2156
1359
1150
462
