I’m running EnSight on a cluster and nothing appears in the viewer. What could be wrong?
    • Stephen Orlando
      I'm running EnSight on a cluster and nothing appears in the viewer. What could be wrong?n
    • wcao
      This could be a few things, likely graphics related. Try launching EnSight from the command line with software rendering, ie ...\v202\CEI\bin\ensight -X. If the model is visible then you know there is an issue with the graphics card. Also go to Help > Technical Support > System Info and check the renderer to see if your graphics card is specified.n
