April 3, 2023 at 2:26 pm
徐 清和
SubscriberWhen I used ANSYS LS-DYNA (2022R1) to export the resulting picture, after setting the exported picture as white background, no matter which frame the animation was frozen in, the exported picture would be the same frame. May I ask how to solve this problem?
April 3, 2023 at 5:53 pm
Armin_A
SubscriberHello there,
Could you describe how do you export the images? I have 2022R2 on my system, so there might be a version difference, but under "Result" tab, when I select the "Images" object, I can export an image at the frame of interest. Make sure the "Update Contour Range at Each Frame" is activated in the graph window (shown with a red arrow in the image below).
April 5, 2023 at 12:59 pm
徐 清和
SubscriberThank you for your answer. I'm using version 2022R1. The language is different, so I'll try to be clear. As shown in the picture,click Image and select,Export to file; If I turn this on(Current graphic display), the image with the blue background is normal,But when I changed the graphics resolution and background options, it was the same image.For example, display time is the box selected 2.9999e-007s, When I wanted to export the picture corresponding to 6e-007s, I still exported the picture corresponding to 2.9999e-007s. How can this problem be solved.
April 5, 2023 at 1:08 pm
徐 清和
SubscriberI'm sorry that I can't upload the picture. I hope you can understand my meaning according to the text description
April 5, 2023 at 3:01 pm
Armin_A
SubscriberI'm not sure if I fully understood your question but here is another suggestion if you're facing issues within the Ansys Workbench LS-DYNA: You can also use LS-PrePost to post-process results of your simulations (it's free software). Once the simulation is complete, the LS-DYNA solver generates d3plot files of the results that can be opened and evaluated using LS-PrePost.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
5162
3275
2453
