April 5, 2023 at 12:00 pm
徐 清和
SubscriberWhen using ANSYS LS-DYNA (2022R1) to export the resulting image, after setting the exported image as a white background, no matter which frame the animation is frozen in, the exported image is the same frame. How to solve this problem?Thanks.
April 5, 2023 at 10:31 pm
Andreas Koutras
Ansys EmployeeThank you for reporting this issue. It occurs also in 2023R1. We will file a bug to the development team.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
5168
3275
2453
